Re: Replacement cylinder for Farmall 400 fast hitc
Posted by Nat 2 on May 25, 2006 at 05:07:01 from (64.80.110.33):
In Reply to: Replacement cylinder for Farmall 400 fast hitch, i posted by Jesse on May 24, 2006 at 18:31:38:
There is no such thing as a "good affordable cylinder." Good cylinders ain't cheap, and cheap cylinders (if such a thing exists) ain't good. There are sites on the net that like to claim that they're discount hydraulics houses, but they're a couple dollars cheaper, if that. Add shipping back on and you may as well buy local.
The important measurements you need are the piston diameter, the distance between the pin centers when the cylinder is retracted, and the length of the stroke. Go shopping. Cylinders are designated by piston diameter and length of stroke, but the "closed length" can vary. Some cylinders are adjustable in this respect.
