Re: farmall h is stuck??
Posted by gene bender on May 26, 2006 at 02:49:51 from (66.43.221.211):
In Reply to: farmall h is stuck?? posted by ryanfisher on May 25, 2006 at 19:24:04:
Remove the starter as it could be locked with flywheel then try crank or rocking wheel that is jacked up and tranny in 5th.
