Re: Farmall M not to full power
Posted by dej(JED) on May 26, 2006 at 10:30:56 from (66.212.151.134):
In Reply to: Farmall M not to full power posted by Mel Stout on May 26, 2006 at 10:20:48:
Having to pull the choke out says that it is starved for fuel a little. One of 2 things come to mind. The first is that you still don't have a good fuel flow. The second thing is that you may have a vacumm leak. If you crack the fuel line at the carb you should be able to see a good fuel flow. Pulling the choke will increase the suction and uplift in the carb.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
