Re: spraying with a 400
Posted by Allan In NE on May 26, 2006 at 13:05:44 from (148.78.243.25):
In Reply to: spraying with a 400 posted by Mcred on May 26, 2006 at 05:07:12:
Leave 'em dished out; put the lugs on the inside of the wheel and mounted to the outermost rib.
That will put you a little closer to the row than you're probably used to, but it works just fine.
Get that wheel pulled in on the axle and the clamp tight first tho, 'cause it is a bear to get at the axle clamp when the rim and tire are sucked in over the top.
Allan
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
