Re: M project
Posted by Randy as in Randy-IA on May 26, 2006 at 14:20:47 from (209.152.95.51):
In Reply to: M project posted by newpuller on May 26, 2006 at 07:16:25:
Well Newpuller , in a word -Yes ! I bought mine off ebay . I don't recommend that unless the tractor is close enough to go look at before you bid . When I got it home I pulled the oil pan and cleaned out the leaves and sludge and a couple of twigs . Anyway , it runs OK and it drives OK and the tires hold air BUT a ton of things are wrong with it starting with the lack of paint . The bearings are bad in the bolster making it tough to turn , the rear end leaks gear oil out the two front seals and it makes a whirring/soft rattling noise when in neutral or any gear unless it's coasting unloaded down a hill at any speed , then it's quiet , the noise might be because when I changed the gear oil the old oil was full of water and with a flashlight I could see that the tranny gears are rust pitted or it could be the front bearings are bad . The muffler is not put on right and it lets rain water seep into the engine and the pto shaft seal leaks . When I put oil in the engine this morning after draining the rain water out the new oil poured out the front crank seal as I was filling it , but it doesn't leak while it's running - go figure - , and the belt drive output shaft seal leaks . The problems I have with mine I hope are all easy fixes since I don't think I'll have to open anything up to fix them unless the tranny noise is a little deeper than the input shaft bearing or the front countershaft bearing , regardless though I'm just going to put in new seals for the time being . But hey , I bought it for something to keep me busy so I guess I got a good one for that ! Good Luck with your's . Take care ! ...Randy
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
