Re: H Farmall Throttle
Posted by riverbend on May 26, 2006 at 18:53:37 from (208.160.33.96):
In Reply to: H Farmall Throttle posted by LarryHFarmall on May 26, 2006 at 17:28:39:
Besides looking at the teeth, see if the handle is bent. I believe that the heel on the other end, and the tooth should be the only parts touching the cap. On mine, the handle was bent down, reducing the spring pressure. Straightening the handle and welding a little strap across the hump in the handle fixed that.
Greg
