Re: Re Torqueing a Cylinder Head
Posted by Phil Creek on May 26, 2006 at 19:11:03 from (152.163.100.65):
In Reply to: Re Torqueing a Cylinder Head posted by scott#2 on May 26, 2006 at 19:02:12:
You never loosen a bolt after you have torqued it..you just place the torque wrench on the head of the bolt and retorque it..just as if you had just installed the bolt. Yes, you are checking to make sure that after warming the engine up that the bolt is correctly torqued. The only time you would loosen a bolt after torqueing it would be if you are checking bearing clearances.
