Re: 756 clutch
Posted by the tractor vet on May 26, 2006 at 19:27:16 from (69.95.207.38):
In Reply to: 756 clutch posted by Dan-IA on May 26, 2006 at 17:55:17:
Sounds like your going to get experence in clutch instalion . It's not that bad . But you will also need a PTO input shaft and maybe a new PTO bearing , i always put a new bearing when i do one and you also have to be careful when installing the two seals . The vary best way of putting the tractor back together is to hang the pressure plate and clutch disc on the input shafts and slide the tractor back together then after the tractor is bolted up then you go thru the inspection cover and bolt up the clutch , this way all that has to line up is the pilot bearing . When ya get done i talk ya thru the adjustments.
