Re: Wide Front for an M Questions
Posted by Nat 2 on May 26, 2006 at 20:42:19 from (64.80.110.33):
In Reply to: Wide Front for an M Questions posted by Pappy on May 26, 2006 at 20:32:15:
The front ends are NOT the same to the best of my knowledge. An H is a much lower tractor, and as such, the front end is lower too. An H's frame is also narrower.
You could make up a steel plate to adapt the H front end to the M, but then the tractor would be running "downhill," and would look pretty dumb..
