Re: 12 volt generator versus a 6 volt
Posted by Bob on May 27, 2006 at 19:59:07 from (64.21.249.40):
In Reply to: 12 volt generator versus a 6 volt posted by MACE on May 27, 2006 at 19:24:28:
Since the voltage regulator controls the voltage output of the generator, you will see almost exactly the same voltage at the "ARM" terminal at the generator, as at the voltage regulator.
With the battery charged up, you'll see about 7.4 Volts out of a 6-Volt system, and 13.8 Volts out of a 12-Volt system.
Alternator regulators typically run a higher system voltage, as high as 14.5 Volts, or so.
