Re: Farmall M not to full power
Posted by alansauto on May 28, 2006 at 22:21:22 from (207.200.116.5):
In Reply to: Farmall M not to full power posted by Mel Stout on May 26, 2006 at 10:20:48:
Here's a tip for finding intake vacuum leaks. Carefully spray the intake gasket area with carb-cleaner (the flammable aerosol type). If you have an air leak the engine will rev up and smoothe out momentarily when it gets a wiff of spray. Don't be fooled by overspray getting sucked in to the air cleaner. Good luck!
