Re: Farmall A changing fan belt ?
Posted by Keith-OR on May 29, 2006 at 22:47:38 from (207.200.116.5):
In Reply to: Re: Farmall A changing fan belt ? posted by dennis in NC on May 29, 2006 at 19:26:53:
Dennis the SC is running, doing the cosmetic on it. Power wash it Friday, had to repair leak in oil pan. put pan back on yesterday. Today did the final wash, I should say Shawn did the final wash. Should be in the paint stage this week. Just did busy work this afternoon, chased threads in bolt holes, always like to clean threads in hole and on bolts.
Glad to hear you made it home alright with JD, and all.Better listen to the "Better Half" can never win an agruement with them.
Cooled off here this last week, had been in the high 90's even hit 100 couple of days. Forcast this week is in the 70's and low 80's, with chance of rain, can use that since I planted new pasture a week ago.
Keith & Shawn
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
