Re: farmall h help tear down
Posted by RustyFarmall on May 30, 2006 at 18:12:44 from (207.32.13.204):
In Reply to: farmall h help tear down posted by ryanfisher on May 30, 2006 at 17:18:18:
If the engine is indeed stuck, and it is very likely that it is, then it is guaranteed that you will be getting in deeper than you wanted to. You can start by pouring some automatic transmission fluid in through the spark plug holes. Transmission fluid is just as good as any magic potion penetrating fluid and is cheaper. the transmission fluid might work, and it might not work. If it works, you can get it out by sinmply cranking the engine over with the spark plugs removed. If it doesn't work, you can get it out when you remove the cylinder head.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
