Farmall Tractors Discussion Board
Re: hard starting 12v 240
Posted by TWOPOP on January 17, 2000 at 08:28:02 from (208.224.41.61):
In Reply to: hard starting 12v 240 posted by 240 blues on January 17, 2000 at 08:13:40:
IS THE COIL YOU ARE USING ONE WITH A BUILT IN RESISTER ? if so remove the chrysler type and do not use. also you said you installed the resister between the coil and distributer. the resister goes between the ingition and the + side of the coil
Post A Followup
: Re: Re: hard starting 12v 240
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
