Re: 240U throttle problems
Posted by Brownie 45 on May 30, 2006 at 18:59:27 from (207.177.82.251):
In Reply to: 240U throttle problems posted by 240U Ed in Wi on May 30, 2006 at 10:56:26:
Before taking the governor off, try seeing if the throttle rod can be moved by hand. If it can be moved & the engine speed varies, there is trouble in the governor probably. If the throttle rod doesn't move easily[engine remains at one speed], look for binding in joints between governor arm & carb. Looking back, I should clarify that the throttle rod is the one which works the throttle shaft on the carb.
