Re: cub rearend noise
Posted by Brownie 45 on May 30, 2006 at 19:07:33 from (207.177.82.251):
In Reply to: cub rearend noise posted by russ hamm on May 30, 2006 at 10:37:01:
Can you determine if there might be a bent fork which could be moving 2nd gear too far, or not far enough when engaged? It could be that the sliding gear is making contact with a gear ahead of or behind it when engaged. Try holding a small amount of pressure on the gearshift lever front & backward to see if the noise gets less. Or more.
