Re: Cub Transmission Shaft
Posted by Bob Underwood on May 31, 2006 at 02:48:09 from (72.69.91.250):
In Reply to: Cub Transmission Shaft posted by Roger46 on May 30, 2006 at 19:26:39:
I don"t think there will be any problem. Had to remove my engine, then looked back thru the torque tube to see the seal leaking badly so had to remove the torque tube. I put a railroad jack uner the differential and a small hydraulic under the draw bar. You should put some wedges under the radiator casting that will keep it from twisting.
Bob
