Re: To ihc49er
Posted by ihc49er on May 31, 2006 at 16:02:28 from (209.115.232.65):
In Reply to: To ihc49er posted by newpuller on May 31, 2006 at 12:02:01:
maybe i am wrong, but i took 44M as 44 massey and to me it is straight forward and simple machine.i replaced these seals over 30 years ago at17 on my uncles tractor.all you have to do is remove brake cover,brakes, brake pulley , then you will come to the seal which holds out diff oil from leaking into brakes,i call these pinion seals.you dont have to get into any bullgears or anything else.i hope were on the same page and this helps you out.you dont need a book to do this. just set up both brakes the same after. probably have to replace the brake bands also.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
