Re: Farmall H sputters and loses power when worke
Posted by old on May 31, 2006 at 18:57:29 from (4.245.1.73):
In Reply to: Farmall H sputters and loses power when worked ho posted by 9N'er on May 31, 2006 at 15:26:50:
How long does it take before it starts haveing problems?? If it like an hour or so then I would guess the coil in the mag is going bad.
