Re: Farmall A Exhaust lift parts
Posted by BillWV on May 31, 2006 at 19:08:04 from (129.71.136.18):
In Reply to: Farmall A Exhaust lift parts posted by Dels A on May 31, 2006 at 18:04:32:
Exhaust lift parts go through on ebay occasionally. There is a control valve housing on there now. You could try e-mailing the seller of that part if it isn"t what you are looking for.
Otherwise try posting a "wanted" ad in the YTMag classifieds.
Good luck,
Bill
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
