Re: 706 getting some work in.
Posted by old on May 31, 2006 at 22:32:47 from (4.244.186.27):
In Reply to: Re: 706 getting some work in. posted by Kelly C on May 31, 2006 at 21:05:48:
Nope when you brake one in you should work it just like it will be later other then don't lug it down. Also varie the RPM a lot. If you don't work it hard it will not brake in like it should and when you start working it hard you will drop the bottom right out. Sort of like buying that car the little old lady drove, she drove slow and then when its taken up to a good speed it blows up
