Re: Farmall H sputters and loses power when worke
Posted by 9N'er on June 01, 2006 at 01:23:17 from (4.233.134.244):
In Reply to: Farmall H sputters and loses power when worked ho posted by 9N'er on May 31, 2006 at 15:26:50:
Apparently it will run for 45 minutes or so and then the sputtering will start and the power loss.
He said that it is not red-lining, but just doing the usual working and hogging a field.
What did you use to insulate the fuel line?
I'll ask him to vent the cap, and I will install the insulation on the line.
To me, it sounds more like a coil issue, but will try the other easy fixes first...
Tom
