Re: Another Farmall A question: Changing oil press
Posted by Nat 2 on June 01, 2006 at 05:54:05 from (64.80.110.33):
In Reply to: Another Farmall A question: Changing oil pressure posted by Eben Merrill on June 01, 2006 at 05:22:02:
What can you look forward to? A functioning oil pressure gauge! :)
Really, it's straightforward and simple: Unscrew the old gauge, screw in the new one. It may be tight, and if the old gauge doesn't have a hex on the back for a wrench, you'll need to use a strap wrench on the gauge body. On the older gauges, there are two holes in the back that one of those "spanner" style wrenches for angle grinders should fit into. Worst case, destroy the old gauge until you get down to something you can grab on to with a pair of vice grips.
