Re: E-12 Carb on My M
Posted by Dave Slater on June 01, 2006 at 15:46:05 from (205.188.116.133):
In Reply to: Re: E-12 Carb on My M posted by new puller on June 01, 2006 at 15:12:05:
Main jet is pressed in,if you have a set of numbered drill bits you can carefully clean it in the carb.If the passage is stopped up past the jet, its realy not going to help much to take jet out as you won't be able to get to most of it. Put it in carb cleaner for a day or so and try air pressure. Not sure without checking, But going by memory I think the stock main is in the .052 to .055 size range.
