Re: Engine Locked Up
Posted by Danimal2 on June 01, 2006 at 17:12:55 from (63.98.154.242):
In Reply to: Re: Engine Locked Up posted by GC KS on June 01, 2006 at 06:59:41:
Well, I just got home from work. I removed the starter and was not able to rotate the engine by hand. Yes I removed the coil wire from the magneto to keep it from starting as I do not have a kill switch as of yet. I did move between the gears (thank you everyone for the gear pattern). It seems to be seized tight as a drum.
Any advice?
