Re: 666 gas
Posted by K.B.-826 on June 01, 2006 at 17:20:54 from (24.180.143.24):
In Reply to: 666 gas posted by GMM on June 01, 2006 at 14:26:09:
Oil runs down the push rod holes from up above. As to why the front lifter didn't have any oil in it, are you saying it was totally dry, or just not as full of oil as the others? Some of those lifters had a oil hole in the side to allow oil to get out and around them, and some did not. Mabey you've got one oddball. No reason why oil shouldn't be getting to it, unless you've got some extreme deposits. As to the valve train noise, do you know when the last time the valve lash was adjusted? If not, it's time to adjust.
