Re: (H) she aint stuck!!!!!!!!!!
Posted by El Toro on June 01, 2006 at 18:09:38 from (205.188.116.133):
In Reply to: (H) she aint stuck!!!!!!!!!! posted by ryanfisher on June 01, 2006 at 16:21:54:
If your tractor has a magneto, the battery is only used to crank the engine. The mag creates it's own spark when the magnets pass by the coil.
I would install a new ground and use 00 cable.
Change the battery cable to the starter too with 00. Unhook the grounding cable on the mag until you get it running. You can pull the coil wire to stop the engine. Those points in the mag need to be adjusted to .013" and cleaned until nice and shiny. Use 320 grit if you don't have a point file. Hal
