Re: belly pump seal on h
Posted by Tom Windsor on June 01, 2006 at 20:54:30 from (64.12.116.65):
In Reply to: belly pump seal on h posted by jon 119 on May 30, 2006 at 18:37:45:
You might do a search on this forum...I saw the same question and discussion before some time back.
I have not been as lucky as others with this thing. I did not change the front one but did the rear one. I wound up with the biggest pipe wrench I could find that would go up in the hole and get a grip and the biggest and ugliest son that I had to sit and push the pipe wrench with his feet while propped against the right wheel. Tractor was in gear and wheel scotched. After straining and grunting it broke loose.
TW
