Re: Cub caburetor
Posted by Bigdog on June 02, 2006 at 07:38:02 from (24.160.186.32):
In Reply to: Cub caburetor posted by spray004 on June 01, 2006 at 21:08:23:
The Zenith carb will bolt up to the cub manifold. The flange on the carb will stick out all around the manifold flange but it will work. The only thing you really need to watch for is interference between the butterfly and the manifold bore. Most of the manifolds have a slight bevel at the mounting surface. If yours does not, you can either bevel it or add a second gasket which will provide enough clearance.
