Re: M Burning Points - Question from Bob M
Posted by arod on June 02, 2006 at 08:18:07 from (206.126.18.18):
In Reply to: M Burning Points - Question from Bob M posted by Wicksfield on June 02, 2006 at 06:53:38:
NAPA:
12 Volt distributor parts.
  • IC10SB -Mileage Plus, ignition coil
  • ICR13 -ECHLIN, coil resistor
  • PR143 -ECHLIN, rotor
  • RR145 -ECHLIN, cap
  • RR174 -ECHLIN, condensor
  • CS763P -ECHLIN, contact set
