Re: Opened up the B--What next?
Posted by El Toro on June 02, 2006 at 16:49:47 from (64.12.116.65):
In Reply to: Opened up the B--What next? posted by bshannon on June 02, 2006 at 15:33:52:
Unbolt one of the connecting rods and use a piece
of 2X2 oak to see if you can drive out the piston or the sleeve and piston. The sleeves aren't pressed into the block. Use can use an acetylene
torch to heat the sleeve once you get them removed. The old rods can be used on the new pistons. Hal
