Re: SA Coil
Posted by Keith-OR on June 02, 2006 at 17:52:31 from (207.200.116.5):
In Reply to: SA Coil posted by Steve Santini on June 02, 2006 at 11:23:36:
Steve I read your post down below or your thread about coil, 6 volt and other items.
1. 3 cell battery is 6 volt (each cap is one cell)
2. Farmall SA is positive + ground, not negative - ground
3. Coil should be hooked up - lead coming from ignition system and + hooked to the distributor.
4. I have found that one of the reason coils heat up and or fail is, that the oil has leaked out over the coarse of years. The coil is filled with transformer oil,which acts as a coolant.
Keith & Shawn
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
