Re: reverse pollarity dc current on farmall super
Posted by Janicholson on June 03, 2006 at 17:48:55 from (66.173.50.122):
In Reply to: reverse pollarity dc current on farmall super c posted by Wayne Merritt on June 03, 2006 at 16:31:21:
We need more info,
Do this test, or explain more.
With tractor off turn on lights. If amp gauge goes up towards the right, the amp gauge is in backwards.
If it goes down toward left, it is correct. If downwards when running, the charging system needs help, and we will need:
The battery voltage, type of generator or alternator, regulator (if any) ground polarity (Positive, or Negative gound). and what the symptoms are.
JimN
