Re: help with oil pressure
Posted by El Toro on June 05, 2006 at 03:49:44 from (64.12.114.138):
In Reply to: help with oil pressure posted by donice on June 04, 2006 at 21:43:31:
You should plasti-gauge the rod and main bearings for clearance. Worn cam bearings can cause this problem too. You should've pull the engine and have an auto machine shop to dip the block, install new cam bearings and have them measure the crankshaft. It may have required undersize bearings. Hal
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
