Re: removing fan on 400
Posted by CNKS on June 05, 2006 at 11:23:36 from (204.249.178.138):
In Reply to: Re: removing fan on 400 posted by Farmall Frank on June 05, 2006 at 10:19:46:
It's called a water pump "drive" pin in my H parts book, and a water pump "driver" pin in my M parts book. Shaft pin or wedge block are good descriptions also. I suppose the 400 could be different, but I don't think so. I have an old Super H water pump. I went out, took off the nut, pushed on the THREADED end and it came out. The bolts with the springs on them just screw out.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
