Re: MW gov farmall H
Posted by Bob M on June 05, 2006 at 19:22:21 from (69.205.112.176):
In Reply to: MW gov farmall H posted by Kevin on June 05, 2006 at 12:42:05:
Rusty has it right...
The only difference between the M&W and stock governors is the M&W has less droop - ie. it reponds quicker as load is applied. This makes the tractor feel a bit "snappier" under variable load conditions. However if you put it on a dyno you'll find an M&W gov alone provides no increase in power whatsoever.
