Re: Farmall 140 hydraulic touch control
Posted by Randy I on June 06, 2006 at 13:01:55 from (67.140.72.219):
In Reply to: Re: Farmall 140 hydraulic touch control posted by Pete7 on June 05, 2006 at 15:07:20:
No, the arms are not hooked up at the moment, and a I said it went up and down several times, then....nada. I guess it is back to the bench, but first I guess I will pull the battery and try pulling the cyl head/cover off so I can get a look at the valves and see if a bit of junk got in the valves.
And no I didn"t use the blue goo, i bought a seal and gasket kit from the dealer, BUT the person before me HAD used blue goo and perhaps a bit of that was floating around the resevoir.
Anyhow, thanks for the help, I will let you know what I find.
Randy
