Thrust Bearing on bolster/400
Posted by SDE on June 07, 2006 at 03:41:58 from (69.179.7.75):
I think this bearing was quite expensive when I replaced it on my other tractor. Is it going to cost about the same everywhere I go, or should I shop around? What else should I expect to replace while it is apart? The steering is so stiff that even in 5th gear it is tough to control or move the steering wheel. It wasn't that bad the first time I got her going this spring, so something is just not right anymore.
