Re: Need some more power!
Posted by Janicholson on June 07, 2006 at 19:11:17 from (66.173.50.56):
In Reply to: Need some more power! posted by jfarmall on June 07, 2006 at 16:29:53:
There are two ways to get power, Displacement, and Compression (assuming that running the enging RPM up in the area of 2200 is not good for long life)
Compression can be taken to 8.5:1 and still run regular gasoline. High altitude head (5000ft) and firedome pistons are the answer to that. The H engine can be enlarged some, but requires a rebore of the cast cylinders (then dry sleeves installed) for real increases. in displacement.
The cam from a 350 will also make more power.
Good luck, JimN
