Re: Farmall Cub with Mower
Posted by Jack in Ohio on June 08, 2006 at 07:43:14 from (192.31.106.34):
In Reply to: Re: Farmall Cub with Mower posted by Stan(PA) on June 08, 2006 at 07:12:34:
That's not stupid, I must admit my blades were running backwards when I took the deck off my Super A and put it on the Cub. I noticed after an hour, so I crossed the belt between the idlers and the deck to switch the rotation.
Also, make sure the blades of the mower on the cub are a little lower in the front than the back, will make a big difference.
That deck is a lot for a cub if not adjusted right or if the grass is very thick.
At my previous house I could mow in second gear, this house has thicker grass and I mow in first gear. Hence the Super A!
Jack
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
