Re: Plowing snow with Farmall C
Posted by bruce Omn on June 08, 2006 at 10:48:29 from (148.150.136.182):
In Reply to: Plowing snow with Farmall C posted by RMO/MN on June 07, 2006 at 16:35:56:
Our C works great with a 6.5' blade about 3' high. The hydraulics run from the back pto with an add on hydraulic pump. The lift lever is behind the operator, not too hard to reach it.
I use 3rd gear to run a good 100 feet. With the straight blade with ends it spills out but it's not too bad. It can handle 8" of snow this way.
Bigger ends on the blade would reduce spillover, and it is a little tedious shifting to neutral to lift the blade. Cut the throttle before pushing in the clutch at the end of the push.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
