Re: Farmall Cub with Mower
Posted by Janicholson on June 08, 2006 at 14:14:42 from (199.17.6.122):
In Reply to: Farmall Cub with Mower posted by Shaun Murray on June 08, 2006 at 06:42:09:
The best solution to the whole problem is to mount a 16 hp kohler, or Honda vertical shaft motor on the deck. The advantage is that total speed control can be the tractor's function, while the mower is powered by enough shaft HP to do the job. 14 to 16 hp would be optimal. I have done it twice with mowers, one a 12hp 40" and one 50" 24.5 HP.
JimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
