Re: Transmission question
Posted by Dave Slater on June 08, 2006 at 14:52:37 from (64.12.116.65):
In Reply to: Transmission question posted by newpuller on June 08, 2006 at 10:25:38:
Sounds like you have top off transmission already. If so drain oil remove PTO,belley pump and split tractor or remove drive shaft from clutch to trans underneath through pump hole.Remove input shaft housing with input shaft.Unbolt the 3 bolts that hold main or pinion shaft in,slide forward and remove keeping the shims to go back if using the same pinion.Remove brake return springs and linkage,remove brake spring return lever left side and clutch pedal.Remove any burs on shaft.slide brake pedals and shaft to right until the end is past counter shaft rear bearing.remove retaining ring from counter shaft at rear of bearing.The bearing needs to slide out of housing and off shaft to rear.Remove belley pump drive lug from front of shaft.Tip its best to loosen this nut before removing top trans shaft.lock in 2 gears to keep it from turning.drive lug is right hand threads.Next remove front retainer with seal,counter shaft slides to rear out of front bearing.Now if you hold your mouth right you can lift shaft out top with gears on it.Kind of long hope I didn't miss anything and good luck.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
