F-14 not running well
Posted by tractor ed on June 09, 2006 at 07:57:28 from (142.167.69.215):
When the tractor is first started it will run fairly well. But as it warms up it seems to run lean. The plugs are black and sooty. When tested with a screwdriver the fire jumps about 1/16 of an inch. It has a magneto that has sat for about 30 yrs. but it still fires. Maybe the mag. could be weak. What puzzeles me is that it will idle but when you open throttle up it will shut off and sometimes backfire. Does this sound like fire or gas? It seems the longer it runs the worse it gets. The last time it started missing. Any ideas???? Thanks for your help in advance...
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
