Re: Dent in Gas Tank
Posted by Red Dave on June 09, 2006 at 17:14:10 from (66.109.236.215):
In Reply to: Dent in Gas Tank posted by Douglas Fisk on June 09, 2006 at 17:03:45:
I've worked on dents in these tanks and lemme tell ya, the steel they made them out of is thicker than it looks. I had one that had a dent in the side so I had a local body shop use their stud welder to weld a stud on the dent to pull it out. They tried 5 or 6 times, but the studs just pulled loose before the dent moved.
I ended up just filling it in with Bondo. Just put on about 1/4 inch at a time and let it get hard before the next layer. If you try to fill it all at once, it can crack. it's been 7 or 8 years and it still looks like there was never a dent there.
