Re: Dent in Gas Tank
Posted by Dan Bear Kelley on June 09, 2006 at 18:42:33 from (140.32.120.188):
In Reply to: Dent in Gas Tank posted by Douglas Fisk on June 09, 2006 at 17:03:45:
Here's a thought. Plug the holes in the tank and put a couple PSI of air into the tank. Go easy! You don't want a sheet metal balloon. You just want a little force working in your direction. Then you may be able to assist the air by lightly bumping the metal at the edges of the dent. OR, you could try the stud welder system, assisted by air pressure this way.
