Re: Low Ash Oil?
Posted by PAULIH300 on June 10, 2006 at 07:30:38 from (152.163.100.65):
In Reply to: Low Ash Oil? posted by IaGary on June 10, 2006 at 07:21:46:
I believe low ash oil is required for diesels as it leaves less deposits behind as the oil breaks down under the intense working heat of a diesel engine.It wouldnt change oil burning at all.You might add a bottle of Lucas oil treatment to see if it slows consumption down.
