Re: Low Ash Oil?
Posted by andy r on June 10, 2006 at 08:57:29 from (69.66.148.45):
In Reply to: Low Ash Oil? posted by IaGary on June 10, 2006 at 07:21:46:
Low ash oil will not help your oil consumption. Here is what I have gathered about low ash oil. When the scraper oil ring on the piston wipes the oil from the cylinder wall on the downward stroke it still leaves a film of oil on the cylinder wall. This oil will burn when the gas/air mixture is ignited. If it is not low ash oil it tends to leave an ash like residue left from combustion. This residue creates the deposites on the valves, spark plugs and tops of the pistons. Eventually these deposites can grow and make a valve not close properly causing a burnt valve. Other deposites can flake off and get under a valve causing a burnt valve. I have a 706 that has drank oil also without any smoke. The problem has always been weak scraper oil rings. The engine always had good power as the compression and oil rings sealed things up good enough. It was just that the scrapers were worn out. Last time it just got new rings and bearings. The time before it got sleeves, rings and bearings. When they drink oil you have to keep hot plugs in them to keep them firing. Eventually they get so bad you can't keep oil in the crankcase.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
