Re: Low Ash Oil?
Posted by K.B.-826 on June 10, 2006 at 12:57:37 from (24.180.143.24):
In Reply to: Low Ash Oil? posted by IaGary on June 10, 2006 at 07:21:46:
Andy's right on. Also, IH six-cylinder gas engines (C-221, 263, 291, 301) were designed to allow more oil down through the valve guides than many other engines. Using non low-ash oil WILL cause a burned valve.
