Re: Farmall H with broken PTO and slipping MW Clut
Posted by Marv on June 11, 2006 at 14:20:30 from (69.66.73.177):
In Reply to: Farmall H with broken PTO and slipping MW Clutch posted by Fermier on June 11, 2006 at 13:44:19:
I recently removed the M&W clutch from my recently purchased SMD. The unit was total junk.
To remove:
> Remove the PTO unit.
> Remove the bolt that bolts the left bull gear to the left axel.
> Pull the left axel away from the bull gear.
> Pull bull gear away from brake shaft housing.
> Remove the M&W kit.
> Move bull gear back into its original position.
> Slide left axel back into the bull gear.
> Screw bolt back into axel.
> Reinstall the PTO unit.
> Install brake drum.
> I installed new seals and gaskets were applicable. Marv
